Steering head grease - those who do their own servicing
Old 11-08-2009 | 05:50 AM
kingkingking's Avatar
kingkingking
Default Steering head grease - those who do their own servicing
My shop manual says to use Special Purpose Grease pn 97blahblahblah in the steering head.
Those who service their own bikes - are you using the genuine grease or do you just use whatever is in your grease gun??
Old 11-08-2009 | 06:10 AM
hojones's Avatar
hojones
You will get a lot of opinions on this subject. One thing I will tell you is if you follow the service manual you will have a mess when the grease expands and starts coming out.
Old 11-08-2009 | 06:29 AM
meatball64's Avatar
meatball64
I don't grease mine. In the summer that drips all over my garage floor and I'm tired of cleaning it up. Their greased when the bike is assembled which should last and really how much movement occurs in that area? It's mostly at very low speed. I mean there not wheel bearings. If they start to make a grinding sound I'll change them. But if want to lube yours any general purpose grease should work, it ain't the space shuttle.
dynaholic77 (06-24-2022)
Old 11-08-2009 | 06:37 AM
n8dc's Avatar
n8dc
I did mine and I just used a tube from tractor supply cause when I went to buy it I bought a case .. No sense buying more !
Old 11-08-2009 | 06:40 AM
dog155's Avatar
dog155
All I have ever used is a heavy axle grease,only pack the bearings,never have leakage.It does not need to be as often as they say.
Old 11-08-2009 | 07:04 AM
dontdropit's Avatar
dontdropit
I grease mine according to the schedule, find a grease that does not drip if you like.
Old 11-08-2009 | 07:23 AM
stevepacman's Avatar
stevepacman
I've been using HD's grease. I don't care for the low drop temperature (especially in Florida) but I'll deal with it. If you haven't thought of it already, you'll save tons of time if you replace the stock zerk fitting with a 45 deg fitting. Otherwise you have to remove the entire nacelle (a.k.a headlamp bucket) to get to it.
Old 11-08-2009 | 07:27 AM
bagga's Avatar
bagga
i never greased mine. 76 shovel and an 85 bagger still have whatever grease they put in from the factory the day it was built. never had a problem.
Old 11-08-2009 | 07:39 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Sponsor
Use what's in the grease gun, and wipe the bottom of the steering every so often to keep from getting this drip that people are talking about. Never have seen mine drip and it get's greased when it is supposed to.
__________________
Old 11-08-2009 | 08:30 AM
Shank's Avatar
Shank
i went with a 45 degree zirk fitting and used a high temp white lithium grease,,it made a mess but i just wiped it up and havent had any dripping, it being a high temp grease,,,,and i know at least there is grease in there !
i problably wont be greasing it again for a real long time,,,,,
Quick Reply: Steering head grease - those who do their own servicing
