Steering head grease - those who do their own servicing
Old 12-08-2009 | 11:14 AM
Skip's Avatar
Skip
I have always used marine grade. Have it for my boat so just use it on the bike.
  #42
Old 12-08-2009 | 12:42 PM
dooz28's Avatar
dooz28
Default A mess
'09 FLHT was greased as part of 1000 mi. service at dealer in April. Was wiping it (and the bike) daily all summer; especially on sides of gas tank and fronts of saddlebags. Next service I'll certainly tell them to do only the bare minimum with the grease gun. Seems like some sort of cuff could be designed for the bottom of the tube.
  #43
Old 12-08-2009 | 12:50 PM
JnT4Life's Avatar
JnT4Life
Originally Posted by meatball64
I don't grease mine. ......really how much movement occurs in that area? It's mostly at very low speed.
Ditto
  #44
Old 12-08-2009 | 01:14 PM
meatball64's Avatar
meatball64
Mine did that for four years and it was only lubed one time. I traded for the 09 and it's not getting any grease.
  #45
Old 12-08-2009 | 02:57 PM
fnbagger's Avatar
fnbagger
Lucus red & tacky. Never had a problem with it dripping
  #46
Old 12-08-2009 | 04:41 PM
carpetride's Avatar
carpetride
What a bunch of friggin greasers
  #47
Old 12-08-2009 | 05:10 PM
patriotmc's Avatar
patriotmc
Dumb non-wrench question. I had my bike serviced around 20K. They did the front end..fluids (?). Can't remember, but it was expensive.. $5-600. Is this greaser thing the same? If so, I won't have that done next 20K
  #48
Old 12-08-2009 | 05:17 PM
patriotmc's Avatar
patriotmc
Ah, found it -- Front Fork Oil... that was what took the time. Does this need to be replaced that often? If I go every other, will I get into trouble?
  #49
Old 12-08-2009 | 05:42 PM
Glenn W's Avatar
Glenn W
The thick blue Johnson/Evinrude marine grease works great.
  #50
Old 12-08-2009 | 05:52 PM
bigskyhd's Avatar
bigskyhd
I use marine grease, just to ensure the waterproof protection. You've got to get the 45 or 90 degree zerk to make it work with a normal grease gun. If not, just roll into your local HD shop, and ask the service manager to hit it once with theirs. They did that for me for a long time till I just bit the bullet and changed the zerk. They'll usually just do it for free.
Quick Reply: Steering head grease - those who do their own servicing
