Steering head grease - those who do their own servicing
Old 11-08-2009 | 08:40 AM
Faast Ed's Avatar
Faast Ed
Originally Posted by HarleyGoodies
Use what's in the grease gun, and wipe the bottom of the steering every so often to keep from getting this drip that people are talking about. Never have seen mine drip and it get's greased when it is supposed to.
I was wiping mine off my fuel tank for the entire first season of my bike, just from being over greased at the Dealership when new. They located this bike and had it transfered from a different dealership, so I suspect that it had been done twice.
I finally can wash the bike without finding grease in that area.
I won't put another grease gun near it for a long time. LOL
1flhtk4me's Avatar
1flhtk4me
Agree.
The bottom tripple tree has pockets casted in the surface,at least on the '06 and prior .This is where all the excess grease will collect.
If cleaned out periodically,there should be no drip.
Old 11-08-2009 | 08:42 AM
meatball64's Avatar
meatball64
It will never need any more---ever.
Old 11-08-2009 | 08:45 AM
MI_Jim's Avatar
MI_Jim
I'm in the "whatever's handy" catagory, but I plan to pick up some royal purple NLGI #2 when I find it. I've been told that and Blue Marine grease are both "non-drippy" even in hot weather. (Probably others also.)
I definitely recommend changing the zerk to a 45 or maybe even a 90 degree. I used a 45 but it looks like a 90 would work considering where the zerk is mounted.
Old 11-08-2009 | 09:46 AM
HarleyWood's Avatar
HarleyWood
I use this, It seems to work well.
AlleyKatt's Avatar
AlleyKatt
Go to your local John Deere dealer and buy a tube of corn header grease. It's a high temp grease that will not melt nor drip. Used it for 2 years and never had a mess.
Old 11-08-2009 | 09:59 AM
Barrenmug's Avatar
Barrenmug
Me too.
Old 11-08-2009 | 10:30 AM
Skulmn's Avatar
Skulmn
I use "green grease" on the recommendation of you forum guys...I have not had it in heat, but it is NOT supposed to melt.
I also bought the 90 degree adapter for the grease gun and left the factory zerk fitting. Easy to use and only $5.95.
Be prepared to use a lot of grease...It was apparent that they did not put any in at the 1000 mile service.
Old 11-08-2009 | 12:20 PM
iclick's Avatar
iclick
Originally Posted by kingkingking
My shop manual says to use Special Purpose Grease pn 97blahblahblah in the steering head.
Those who service their own bikes - are you using the genuine grease or do you just use whatever is in your grease gun??
I don't think it matters much, although I used Royal Purple NLGI #2 synthetic grease on my old RK and never had a problem with the steering head, or much of anything else, in >100k miles. I continue to use it on my SG and have noticed that this grease does not ooze and drip on the fork like the stock grease does. Also, a friend who services cranes uses RP grease and claims much longer service life on crane parts lubed with grease, which are obviously under more strain that our steering heads. It's probably overkill for our purposes but at only $10/tube and readily available here I see no reason to change at this point.
Old 11-08-2009 | 02:11 PM
BLKBAGGER's Avatar
BLKBAGGER
I use some blue boat trailer grease that has been around for a few years. I can't remember the name of it right now but it's good stuff.
Quick Reply: Steering head grease - those who do their own servicing
