Rear tire harder to remove than I thought..
Old 03-03-2011, 10:21 PM
103 sedona orange's Avatar
103 sedona orange
103 sedona orange is offline
so, how much did you save my doing your own tire?
  #42
Old 03-04-2011, 08:04 AM
piasspj's Avatar
piasspj
piasspj is offline
Depends on how much your dealer or indy charges. My last tire cost me $106 and a few hours time (I spent some time cleaning the rim and pulley and other hard to reach places on the bike).
At most places you can take your wheels in and it is cheaper than if they have to remove and reinstall them on the bike. Most places don't like mounting and balancing tires you bought somewhere else, some simply refuse to do it.
  #43
Old 03-04-2011, 10:39 AM
Road Ranger's Avatar
Road Ranger
Road Ranger is offline
Originally Posted by Upswept
The most important part of the job is getting the torque right on the axle nut. You can't do it right without a torque wrench, and not one from harbor freight. They are unreliable and go out of spec without warning. Harbor freight is the biggest problem with Harley fasteners. Stay away from harbor freight torx and allen socket bits.
I bought a torque wrench from HF and it has never fallen out of calibration. I bring it in to work once a year and have our calibration specialist inspect it for me and it has never been out by much. Any torque wrench can go out of spec w/o warning...It all depends on how you store it. Prior to stroring, all torque wrenches should be backed off to 0 NM's as not to put undue or constant stress on the internal spring, this is what causes them to go out of spec, not because it was purchased from HF.
I disconnected shocks in order to remove the wheel on my 05. I didn't have to take off the mufflers, but I did have to remove a portion of the saddlebag support to get the axle out.
  #44
Old 03-04-2011, 10:53 AM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
Didn't read this whole thread, so don't know if this has been mentioned, but to get easy clearance around the bag guards to remove the axle, just adjust the air pressure up or down in the shocks.
That also works when putting the tire back on, to align the axle holes with the swingarm
  #45
Old 03-04-2011, 11:07 AM
strtarrow's Avatar
strtarrow
strtarrow is offline
Originally Posted by Uncle Scrooge
No problems with axle clearance on my 06. I'm wondering if maybe you had something that blocked the rear swing arm from dropping down some as you jacked the bike up.
My thoughts exactly. I remove top bolt of shock and no problems.
  #46
Old 03-04-2011, 06:46 PM
krazy3's Avatar
krazy3
krazy3 is offline
Originally Posted by HarleyWood
IMO its just easier to remove the mufflers. It takes all of ten minutes and then they are out of the way.
From "the manual":
rear wheel removal
step 5
On models equipped with low profile shock absorbers, remove the left side lower saddle bag rail....
When all else fails...
B&ESPORTSTER
07-02-2017 01:46 PM
warren827
Wheels/Tires
05-06-2015 10:38 PM
ddellostritto
09-22-2011 08:22 PM
JT-FXDL
06-21-2011 05:41 PM
rufusrufgut
11-04-2006 12:40 AM
Quick Reply: Rear tire harder to remove than I thought..
