Had a slightly high RPM after installing, about (1200 rpm). Did the throttle set, let things settle in at idle while hooked up to the putter. No problem since.
I have to do the reset once in a while. Is there an ECM firmware upgrade that fixes this?
Actually there is an upgrade, but I never bothered with it. If memory serves it changes the length of time the ECM looks at the throttle position. I never bothered with it and just trained myself to avoid the throttle when I shut the engine down.
