Broken Stock Exhaust Bracket P/N 65619-98
Also may consider to look if the slip-on mufflers use the square rubber hanger on bracket. He may wish to change those rubber blocks....the rubber blocks harden and cause a squicky noise..cost about $2 or $3 each..rubber block also helps support the weight of muffler..only supports are from L-bracket and that rubber block.
cbass68
11-28-2008 03:54 PM
