Looking for air horn that can be hidden
What someone really needs to work out is a way to get a small air reservoir (tank) and compressor hidden to get the really loud sound. I came across a guy on YouTube who put a setup into one of the saddlebags. Sucker was LOUD.
You could make a small reservoir from a piece of maybe 2" black iron pipe with caps on the end, drill and tap for
npt fittings to run air lines.
I got one of the Wolo Bad Boys on Amazon for right at $42. Mounted it in my wife's Miata, (it's horn is more useless than my Road King's). I mounted it using a relay. My
ears are still ringing from the first time I tested it...
Guess I'm ordering another one for the bike. I like the idea of seperating the compressor from the horn and installing the horn under the stock horn cover.
There is already a write-up about them, but I will snap some pics a little later and post them. The only thing you can see are the fitting for the hose and some clear tubing. That will change with a little braided wrap though.
You would need a pressure switch to keep the reservoir charged up, and not burn up the compressor. I built an on board air compressor for my jeep, and, though the size is a bit overkill for a bike, the parts needed don't really change, as far as switches and such. http://www.kilbyenterprises.com/web-...oba_manual.pdf is a schematic of what I'm talking about.
I also used the Stebel, seperated with the horn under the cowbell and NOTHING sticks out. You cannot tell period. Go to this link, its what I used as a guide to install mine
http://twolaneroads.com/my-ride/harl...n-replacement/
There's really nothing new in the tankless airhorn world (Stebel, MiniBeast, Wolo, HD, Howards, Rivco, etc). What someone really needs to work out is a way to get a small air reservoir (tank) and compressor hidden to get the really loud sound. I came across a guy on YouTube who put a setup into one of the saddlebags. Sucker was LOUD.
