Stage 1 & Stage 2 - What are they?
RE: Stage 1 & Stage 2 - What are they?
ORIGINAL: k23rd
What exactly is the definition of what makes up a Stage 1 and a Stage 2?
Stage 1 refers to a basic upgrade of your bikes engine without changing any internal parts. Upgrades include air cleaner, exhaust, carbs or EFI and maybe ignition. Stage two is the same as stage 1 plus replacement of cam (s) and camshaft bearings. Stage three gets into better flowing heads and higher compression pistons.
Stage I is the basic engine breathing via the breather, exhaust via the mufflers and remapping the ignition on the Fuel Injected Bikes or rejetting the carb. The stage II kit is an upgrade to the engine size along with the cams. The other elements of the stage I are also included. You will get a lot of different types of answers, but that is it in a nutshell.
[IMG]local://upfiles/494/3D0BAD6CB2374F2796718946EF270857.jpg[/IMG]
