View Poll Results: Should this be a helpful *Sticky...
Yes
132
97.06%
No
2.94%
Voters: 136. You may not vote on this poll
First Time Fluid Changers - Helpful Videos...
This was so helpful - I was able to have a few and then a few more while changing my fluids and still felt like I knew what I was doing...
In one night I changed my Motor Oil, Primary Fluid, Trans Fluid, Checked my Primary Chain (no adj needed), Adjusted my Clutch Pack, Clutch Cable, and Throttle Cable and lubed these cables as well... Now I can hit neutral with no effort - my clutch feels easy and my throttle has less lag and snaps right back. All in one night - All my first time. How much did I save??? I'm just guessing over $500.
How to change Motor Oil:
Tools: 5/8" Socket, Strap type Filter Wrench, Filter (K&P optional), Proper O-Ring for plug
http://www.youtube.com/watch?v=Ccq8F...eature=related
How to change Primary Oil and adjust Primary Chain:
Tools: 40torx, 9/16" socket, Allen set, Proper gaskets
http://www.youtube.com/watch?v=k-KVQ...rom=PL&index=3
How to adjust your Clutch Pack:
Tools: Allen set, 11/16" wrench
http://www.youtube.com/watch?v=Zl92w...eature=related
How to adjust Throttle Cables:
Tools: two 3/8" wrenches, Allen set, Cable Lube
http://www.youtube.com/watch?v=jywZRVuJnYY
How to adjust your Clutch Cable:
Tools: two 3/8" wrenches, Cable Lube
http://www.youtube.com/watch?v=iiC5d...eature=related
How to Change your Gear Oil:
Tools: 5/8" Socket, 3/8" and 7/32" Allen heads (varies)
Pictorial and write up:
http://www.dudeworld.com.au/HOWTO.GEARBOX.HTML
Hope this helps...
Hope this helps...
To me it just helps speed things up if you're going to try it anyway.
Its almost like doing anything the second time... it goes twice as fast the second time because you know what to expect.
This gets you there and I'm not promoting anyone or any service... just another dog chasing the proverbial tire here who thought this might help others...
