Fuel Managment; Help Please
Do some research on the different management systems. I've had the V&H Fuelpak and now have the SERT (Screamin Eagle Race Tuner) that I've sent in to have upgraded by TTS (makers of the original SERT). I have no experience with the PC-V, but have heard good things. The PC-V, like many other systems, is a piggy-back module that stays on the bike and is mounted under the seat or side panel. The new TTS, like the SERT, is an interface that connects a laptop/Dyno to your bikes ECM and loads maps and allows changes to be made and does not stay on the bike.
I've sent in my SERT to be upgraded to the new Mastertune system which will allow me to tune my bike as close as possible without paying a DYNO tuner. And everytime a change is made, cams, big bore kit, exhaust, intake, etc., I can retune the bike myself. Granted, you will get many different answers/arguments for and against each different tuner and their abilities. None of them will give the "perfect tune" a real DYNO tune will, but for most people they will get you close enough that you'd be very happy. I'm happy with mine the way it is, but the upgrade to my tuner will give me so much more ability to tune, now and for future modifications.
I spent several hours reading Here and learning about the new system. Talking with many people about it and deciding it was my best choice, given I already had the SERT.
The Fuelpak is a budget tuner and worked ok, but I didn't care much for it's limited ability to tune.
Good luck, you have many options and a boat load of info on here.
Mike in Oregon, you're not to far from me, I'm just north of Vancouver, if you want we can hook up and you can check out my tuner when I get it back in a week or so. Might be good for you to see a few up close and personal.
We have put together some pretty good info on our website on why bikes need to be tuned which can be found here http://fuelmotousa.com/harleymain.htm If anyone has any questions regarding fuel mangement we would be happy to help out
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Quote, "Again, how are you going to adjust without a dyno-tune and know you have the correct AFR's in open-loop mode? You have no feedback (closed-loop) from which to adjust. Although you may get fairly close, I can't buy the guesswork involved in altering VE tables to get a good tune outside the influence of the O2 sensors."
Ignorance is bliss, if it sounds good and by the butt dyno it feels better, it's tuned well enough. I know better, spent many years running an automotive dyno shop and dispelling such myths.
paid4c4
43
02-28-2015 01:53 PM
