Spacers for shifter pegs and brake pedal
Old 10-25-2009 | 07:43 AM
SG 1's Avatar
SG 1
I don't know where to find extentions like your looking for, but here is what I did for the shift lever. I didn't like having to turn my toe in either after the 1" board extensions.
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Originally Posted by brettnbama
maybe you can find longer shift pegs?
That's the ticket!
Old 10-25-2009 | 08:03 AM
lp's Avatar
lp
Thats what I did. Kuryakyn has longer pegs. I usually have a picture. don't right now.
lp
Old 10-26-2009 | 10:47 AM
frenchbiker's Avatar
frenchbiker
Originally Posted by IAMSWUTIAMS
OP is not looking for "spacers", he wants "extensions" to move everything out.
I'm looking at spacers but with a male end and a female end. If it's what you call extension, then yes, that's what I would like to find. I already have the footboard extensions.
I don't want to buy longer pegs and brake pedal. I have the whole HD Nostalgic collection and want to keep them. They match the footboard inserts.
Old 10-26-2009 | 10:55 AM
frenchbiker
Yep, thanks much for the picture. This will work but I'll also mount a shorter spacer for the heel shifter. I guess you had to buy longer bolts for the pegs, right?
You said you didn't do anything for the brake pedal. Actually, that's where I have the biggest problem. Maybe my right foot is turned out more than my left, I dunno, but I want to touch more of the brake pedal than I do know.
Old 10-26-2009 | 11:19 AM
katobird's Avatar
katobird
do a search on E bay for "harley extenders" there are many styles of long shifter pegs....
Old 10-26-2009 | 03:23 PM
frenchbiker
Old 10-26-2009 | 03:24 PM
frenchbiker
Thanks but like I said before, I don't want to replace my Nostalgic pegs and brake pedal, just move them out a little bit, like 1/2" to 3/4" . People who buy chrome footboards inserts from Harley to replace the stock rubber footboards normally buy the matching shifter pegs and brake pedal. It's my case.
I'll put chrome spacers with longer bolts and it should work. Thanks again.
Old 02-18-2010 | 02:00 PM
mr396's Avatar
mr396
FrenchBiker - did you ever figure out out to move the brake pedal out? I would like to move it out an inch or so for the same reasons you mentioned (my knee hits the aircleaner and would rather not have to twist my foot in to hit the brake pedal or at least get more of it than the outside inch or so). I am wanting to do the same thing.
Anyone have any suggestions?
Old 07-31-2010 | 10:30 AM
rrjacoy's Avatar
rrjacoy
3rd Gear
Default Where did you find the bolt
SG 1, I found a 1" chrome spacer at a local hardware store but for the life of me I can't find a machine screw that is an inch longer. Mine appears to be a 5/16-24. I checked hardware stores and the Harley dealerships and no dice. Do you remember where you found yours?
Quick Reply: Spacers for shifter pegs and brake pedal
