New garage door/gate opener from Biketronics
Second, being hooked to the lighting wiring on the bike you can leave your bike outside without worrying about someone opening your garage. It won't work unless the key is on. With yours you either have to carry that thing everywhere you go or leave it on the bike and risk someone stealing it and having access to your garage.
When I'm parked away from home, the transmitter is secure. Even in the highly unlikely event that anyone did succeed in acquiring it, there's no identifying information, and they wouldn't know where to go to use it to get into my place. Obviously, if that DID happen, I'd know it, and I'd just change the code, and we're off to the races again. What's the problem?
Once these units (or the HD unit) is on it is completely transparent and works like a charm. It is one of the best upgrades you can buy for your bike IMO.
I haven't a clue what that means. I buy a gate opener transmitter, I set the DIP switches to match what my opener is set to, and I'm good to go. The "learning remote compatible" business isn't something I've ever had to deal with, and I've been doing this stuff for a lot of years.
http://en.wikipedia.org/wiki/Garage_door_opener
We don't tear all our "older technology" stuff out whenever anything newer comes out. You won't either.
Yes, to hell with "Wikipedia", mine are "older type opener that still use dip "spithes"". They work very well, amazingly enough, and we don't get those "homies" they talk about, roaming the "hood" with their code scanners, ripping off everybody's opener codes. Fancy that. And I'd speculate that a huge percentage of openers currently in use across the country are STILL using that "older" technology.
No doubt your older technology works fine though and that makes us very happy.
lp
Signal should be plenty strong to mount inside the nacelle, behind a side cover, or under the seat. I'm sure someone more educated than I on the "newer type openers" will chime in if I'm wrong....
