How to access aux. switch
Old 10-24-2009 | 12:49 AM
Sandy Mike's Avatar
Sandy Mike
Originally Posted by HarleyWood
Why not just plug it in to the cigarette lighter?
My experience was that it blew the fuse when starting the bike if plugged into the lighter. Worked fine if I started the bike then plugged in, but it seemed to have an extra draw to "kick" the unit on when I started the bike. Not sure if hard wiring it would change that, but I just worked around it knowing what the problem was.
Moral of the story though - if you do have it plugged into the CL and all your guages go blank when you start up - the 15 amp fuse is easy to replace, just make sure you have spares stuck in the holder.
Old 10-24-2009 | 08:55 AM
iclick's Avatar
iclick
Originally Posted by soos
I am surprised that dawg didn't suggest just wiring the GPS to the leads off the headlight plug. Since you have the fairing off, it's a simple job.
The HDI connector near the headlight plug is where I have mine connected. It is an unused plug and a good choice, but if the OP wants to be able to use the ACC switch for the GPS he can splice into the orange wire at the switch. If he just wants a 12V source with no switching ability the O/R wire at the ACC switch will work, but the HDI connector would seem the best if no additional switch is needed. All GPS's I've seen have on-off switches and I don't see why you wouldn't just use it for switching.
Old 08-26-2015 | 03:12 PM
khurtt's Avatar
khurtt
Stage III
Default Help
im also having same problem... But I can't find the power under the seat either.
Old 08-26-2015 | 04:44 PM
AnotherBlackSG's Avatar
AnotherBlackSG
Why are you guys going under the seat?? There's power to draw from all over the place under the fairing. I pulled power for my gps from the hot to the cigarette lighter. Drilled a small hole in the fairing, installed a rubber grommet and ran the wire through it. Wiring it to the aux switch seems like a waste to me.
Old 08-26-2015 | 07:38 PM
White Ice's Avatar
White Ice
You're not really stating what your problem is, or what bike it is. If you're trying to hook up a GPS on an Electra Glide, your best option is to use the capped power/ground wires located under the fairing that are spliced off the headlight wiring harness. The wire is 'hot' only when the ignition is 'ON' or on 'ACC' No need to even use the power switch on the GPS.
The ACC switch has a plug located under the seat, on top of, or maybe in front of the battery. It's a four-pin plug. Save that one for things like heated gear, where the controller is mounted more rearward on the bike.
The ACC plug will look like this - the cap has been pulled out,
rkoivisto's Avatar
rkoivisto
Default GPS in ciggy lighter
My experience was that I was blowing that fuse a while ago with my GPS too. Turned out the real problem was that the power connector on the back of the GPS had all kinds of corrosion from getting wet.
The GPS itself won't pull enough to blow that fuse, but the corrosion forms a short circuit that will.
If that is the case, it will blow any 15 amp fuse it is pulling power through.
Old 07-29-2016 | 01:03 AM
LadderCo2's Avatar
LadderCo2
I'm looking to use the aux plug/button on my 12 FLHTCU. I am getting the HD Y-adaptor. How do I get the male plugs that go into this HD adaptor so I can wire my own accessories without cutting the Y-adaptor female plugs off?
SeanG
2014-2023 Touring Models
03-11-2016 06:13 PM
Splais1
07-30-2012 09:45 AM
bigalsd
05-31-2009 10:39 PM
greybeard6
04-19-2009 10:38 PM
jwmu
06-06-2007 01:15 AM
Quick Reply: How to access aux. switch
