How to use single cylinder mode?
I'm trying to interpret your instructions. I assume the bike engine is running, so why do you say "turning the ignition switch and the run switch"? Wont this turn the engine off or run the starter on a running engine?
Thanks for your patience,
Migs
HDRider2002:
Can you elaborate on the Pursuit position and how to enable disable it? What is it for and what should it be on normally?
Thanks in advance,
Migs
Thanks in advance,
Migs
It may be "normal" for the "P" to be illuminated depending on how the wiring was altered when police gear was removed. Mine was always on, unless i had my passing lamps off, then the "P" went out too. When i changed my speedo, i didn't have the problem anymore. I am sure if you get your hands on the police model wiring supplement, you can trace that circuit back and alter it as you wish. Otherwise, you can just leave it, its not harming anything.
On my 09 RK, the parade mode kicks in automatically once the engine temps hit a certain point. It only kicks in if stopped and in neutral or in gear with the clutch in. You can enable/disable it by turning the ignition switch on and the run switch, then roll the throttle forward and hold it for a few seconds. The cruise light will flash green if its on, and red if its off. As for the red P, I am unsure, I am not sure I have a red P on my lights
don't worry if you don't understand his instructions. it won't work on your bike anyway. my bike is an 07, in order to have the parade mode activated, it is a dealer download. if you're bike is even capable of it, i'm sure that it would also be a dealer download.
The 06 models do not have EITMS. Introduced in 2007 this was an optional one time dealer download to enable it. On 2008 Touring models VIN# XXXXX and later (not sure on the specific vin range) and all 2009 and 2010 Touring models this was standard issue and could be turned off and on by rotating the throttle grip forward while the bike is idling. The cruise control indicator will flash green to activate, orange to deactivate.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
