FuelMoto Stage one on 09 Streetglide!
Ok first I wanted to say great job to FuelMoto on the stage one set up that I just installed on my 09 Streetglide with the new Jackpots. I just had a quick ride on it and I like the sound, just what I was looking for and it seems to run really well, but I am sure that my mileage will go down a little until I learn to quit twisting the throttle so much.
I was wondering on the 09 model headpipes if anybody has a part number and where you can get a plug for the two o2 sensors in the headpipe as the FuelMoto package has you disconnect the sensors and jumper the wires. I would like to remove the sensors so the wires are not hanging around. I did a search and found a part number for a 07 model but I thought they changed the 09 bikes that it might be a different size sensor. Thanks and ride safe!
If I understand you correctly.........you want to removed to 02 sensor WIRING all the way back to the ECU??? I am interested in the same thing on my 07 SG. I don't like the idea of wire tieing them up out of the way.
