rinehart slip on too quiet...help
yesterday i just bought rinehart slipon and installed on my 09 sg.....
and im a little dissapoint with the sound.....coming from my 07 ultra (has rinehart td) which sound very loud.....
the difference is too much....rinehart slip on on my 09 sg is very quiet....just a little louder than the stock.... no high pitch chirping....
any wrong...?? i wish my rinehart sound loud....anything can be done to make it louder..??
thanks bro
thanks bro
My son yanked the baffles (easy two screws on each one) on his TD Rhineharts and wow, it rattled my teeth. When I road it the noise was so loud (I wear hearing aids) I could not hear myself say "Oh S....t!" when I was turning around. They do sell other baffles, perhaps you could swap on the freebie forum.
I removed the baffels and added a Big City Thunder lolly baffle in the head pipe. Sounds a whole lot better in my opinion.
The baffles in the rinharts are huge and a PITA to get out. You have to lube them good with penetrating oil and then beat them from the front side out. You can use the bracket to set it on a ledge of a peice of 6 X 6 block covered by a rag. Use a BFH and something to set against the inside lip of the baffle from the front side. Give it few good whacks and it should come out.
The part number from Big City Thunder is Part# 2002 I believe. It's very easy to install. One hole drilled in the headpipe and screwed it on.
Did you just like the looks of the Rineharts? or just not want to deal with get a different set?
