What psi tire inflation is best?
Go with the tire mfg. maximum recommendation for the style tire you have on. I talk w Dunlop rep years ago and he said always to go with the max to avoid sidewall flex and heat build-up. I wear out tires fairly quickly so maybe somewhere in between to get more side wall wear. Now I'm confussed.
This was most of the problem that Ford and Firestone had a few years ago, Ford was saying inflate on the low side to improve the ride, made Ford feel good so more sales, problem was they produced to much heat and tires began to fail. Not saying the tires didn't have a fault but studies showed that had they been inflated to the Manf.'s recomendations it wouldn't have showen up as often.
Terry
