Too many Rinehart noises and rattles. What to adjust?
Guys,
I have an 08 ultra. I had the Rineheart pipe installed one year ago by the dealer.
But I often get rattling noises specially when the bike is cold. I have replaced the rubber mount a couple of times but now I have other noises that when I am stting on the bike when cold come from the pipes.
What are some potential contact points that I need to check to eliminate these
noises?
noises?
Spend a little time and look your bike over - you'll find any contact points all by yourself. With the motor shut off wiggle the exhaust system and listen closely for noise. With the engine running you can dampen the noise by grabbing the pipe with your hand (when it's still cold). After that you'll need a tool or at least a good glove. The pipe gets hot right away the closer you get to the motor. It may be a loose baffle inside the muffler(s).
I had the same thing happen to me. Double check all of the clamps. The dealer had mine off for some warranty work and at first glance the heat shield clamps were all tight, however the one close to the read cylinder was actually not in the little metal tabs that hold the clamp to the shield from the inside. Basically the heat shield was just sitting there and the clamp was tightened but it wasn't holding anything.
