Throttle sticking open! Help
I ride an 04 Ultra and the other day the throttle stuck open three times when getting hard on the gas, it had to be shut down with the kill switch. The cable felt like it was going back to the right position, any ideas or is it time to bring her in. It has 24K and I just had the 20k service done at 21K. Thanks for any help or ideas you might have.
RE: Throttle sticking open! Help
Your throttle return cable (or both cables) may need to be lubed or replaced. If the cable is frayed (from the inside) it will stick. Also, check the spring at either the injector body or carburator, where the throttle cable connects. Test the spring and make sure it returns.
If you've done all of these checks and they are all fine, your problem maybe in the ECM (if fuel injected.) A lot of times, the dealer will not do this check, unless you're complaining about it.
ORIGINAL: mnbagger
ORIGINAL: mnbagger
Finally got around to looking at my bike. I checked and lubed everything I could, but I didn't see or feel aything wrong with the cables or springs, I guess I will take it in. Thanks for all the help.
Please do, you just looking for an accident if you don't
