HID Interference w/ radio
Old 10-11-2009 | 12:54 PM
SlowGlide2989's Avatar
SlowGlide2989
Default HID Interference w/ radio
Alright I purchased a car HID kit to install on my father and my street glide. I installed a kit on my bike, and have no problems. I have aftermarket speakers and a 120watt amp and a short antenna. I installed the other half of the kit on my dads street glide. He has stock radio, j&m speakers and a hidden antenna. When the ignition is turned on hid turns on there is static in the speakers. I had to take the HID back out of his bike so the radio would work. I rapped the ballast in electrical tape, did several mounting locations, I cannot figure it out. Any suggestions, or any one have a similar issue. Thanks
Old 10-11-2009 | 01:14 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Did you ground the HID lights good?
I would also swap the ballast out with the one in your bike, it may be a bad ballast.
Old 10-11-2009 | 01:46 PM
KoalaCowboy's Avatar
KoalaCowboy
It could also be that the hidden antenna in your dad's bike is being affected by the HID.
I'm not a big fan of the hidden antenna, personally...hope you find a solution. Having an HID headlight makes a huge difference when riding at night!
Old 10-11-2009 | 03:56 PM
SlowGlide2989
im almost positive that its the hidden antenna... But we dont really have any other option. Its an FBI razorback so there is no mount for a conventional antenna.
Old 10-11-2009 | 04:05 PM
bagman1's Avatar
bagman1
Get a non powered hidden antenna then. Mine interferred with my xm so I tossed the antenna and no more issue.
Old 10-11-2009 | 04:21 PM
SlowGlide2989
Thanks bagman I was actually thinking this right as I read your post.
Old 10-12-2009 | 05:54 AM
xtremechopper's Avatar
xtremechopper
Def. the powered ant., had the same issue with another bike. We put on another non powered hidden ant and the problem went away.
Old 10-13-2009 | 01:12 PM
HDSAE60's Avatar
HDSAE60
try alum foil, on your ballast.
lakedrum03
12-06-2014 01:42 PM
lakedrum03
07-05-2014 06:14 PM
gearhead998
Audio Systems
05-12-2013 10:54 AM
pjchops
03-05-2013 04:33 AM
IronHead2822
11-16-2007 09:43 AM
Quick Reply: HID Interference w/ radio
