Rear Lowering Blocks-Junk Or Not?
I know there are many post on the lowering blocks versus the lowering shocks, I would just like a few more opinoins from members currently running the lowering blocks on their 09's and up touring models, specifically a Road Kind standard. I need about 3/4 to 1 inch to be totally flat footed. Already did a seat mod which really helped, and I have seen many (KITS) on e-bay fairly "cheap". Just need to know are these cheap kits just that = junk, or are they really worth putting on a 18000 dollar bike. I know many are running the lowered shocks 279.oo a pair, but was just trying to save some coin for other parts. I know this is a long thread but I am really close to getting one or the other and just need some help easeing my mind on making the right decision, hey thats why we are here to help each other out right? Thanks
You've got hard bags so you can install the lowering blocks. They won't fit on Classics with leather hard bags.
Go for it. I used them for a year on one of my Sportsters and they worked perfectly and didn't harm handling at all. I've also installed them on several Dynas for pals and they are tickled.
No matter how you lower the azz end, you need to be mindful that you place the floor board rear brackets closer to the pavement and it can cause you to skid when leaned over too far, so if you already scrape the floorboards you need to be very careful about lowering your scoot more.
Lowering blocks were popular here on the forum a couple of years ago, however there were several reports of handling problems that they fell out of favor. That, and there was an unscrupulous member who sold some poor quality blocks and guys were having some serious issues with refunds.
If you want my opinion it would be to save up for the shock replacements and not the blocks.
I've been running the blocks in the 1" lower hole for about 10000 miles and have had no problem but don't drive too aggressively in the turns. I live in a fairly rural area with lots of back roads that might cause some bottoming out but haven't experienced it. I am 180 lbs and mostly ride solo and faithfully keep 23 lbs in the shocks. When I have a passenger I go to 50 lbs with my passenger being around 125 lbs.
Oh yes, since you asked about a Road King (standard), I did run them for years on my RK with no issues.
The blocks I used seem to only change the shock angle 2-3 degrees.
While lowering kits are cost effective they can also create problems such as the clank my buddy's bike had after installing a lowering kit. No matter what pressure he tried the clank was always there and the ride was atrocious. I rode it myself and atrocious pretty much hits the nail on the head.
He then installed my take-off stock StreetGlide shocks and the clank problem disappeared completely and ride quality improved immensely. I rode it again and they were a marked improvement (even for stock).
He got my old SG shocks for less than the price of his lowering kit. The swap is too easy and you can find stock take-offs on this forum as well as Craigslist, Ebay, dealerships, etc.
Thanks for the replies, seems all the info that Ive been gathering says its about a 50 50 chance you take with the blocks. Some say no issues others say bottoming out and fender rubbing, guess it comes down to me making the decision. I did come across a place that sells the lowering blocks called E-Glide Goodies, looks like maybe their blocks might be a little better quality than the ones on e-bay, oh well live and learn right? Thanks agian guys.
This little statement on the bitchinbaggers site was enough to steer me away from them.
Yeah there are gonna be plenty of people that have run a ton of miles with no problems. Didn't want to take a chance myself.
A Word About Lowering Brackets
Dangers of using shock relocating brackets
This is the safest most reliable and cost effective method of lowering your Bagger. The use of shock relocating brackets should never be considered! Over half of our customers have come to us because of problems encountered from the use of these types of lowering devices. Phoenix Customs does mechanical design and machining, we could easily make these brackets ourselves but frankly I would be embarrassed to attach my name to that junk and even more embarrassed to ask you to attach it to your Harley.
- Changes critical shock angle causing rough ride.
- Stability issues and increased bagger wobble.
- Can cause the lower shock eyelet to break off.
- The brackets often times break from flex and fatigue caused by increased shock angle.
- Clearance issues with bags due to increased shock angle
- Allows tire to come in contact with fender, VERY UNSAFE, if you're lucky it only burns up your tire, the paint on your fender and the tail light wiring harness.
If you are trying to save money, find a set of lower Takeoffs...You will probably be much happier in the end and have no risk of having to do it twice.
