Pics of how your cables are ran with 16" apes
Received 5,269 Likes
Look close at his pics and you will see that his upper brake hose has a 90 degree bend where it meets the master cylinder....Looks killer, huh?...It's also sic the way the hose follows the curve of his bars too.....Mine looks like that.
Get your cables and hoses from Magnum Shielding like I did(I bet he did too) Select their 'designer series' and chose your color. They will make the upper brake hose EXACTLY like you need it and it will look as fine as his if you spec the upper 90 vice the stock 35 degree bend(the 90 will fit even if you use 1 1/2" fat bars).
First install the bars, then carefuly measure from the top of the lower triple tree up to the master cylinder using string and taping it to the bars-that is how long you need the upper hose.....the lower hose is a separate assembly where all you spec is stock length and will attach to the upper hose using universal swivel fittings they include automaticly.
