Penetrant test results
Old 10-06-2009, 05:10 AM
jpooch00's Avatar
jpooch00
jpooch00 is offline
Originally Posted by jag1886
Does acetone kill plastic containers? I know it kills rubber so you can't use most readily available pump sprayers. What would you put ATF/Acetone it in to spray it???
How about an old fashioned all metal oil can? The kind with a pump in it and a long output tube.
Old 10-06-2009, 07:23 AM
masterblaster's Avatar
masterblaster
masterblaster is offline
Jet A or Kerosine
Old 10-06-2009, 08:17 AM
tx-skydiver's Avatar
tx-skydiver
tx-skydiver is offline
Thanks for that. I generally use PB Blaster and now Royal Purple Penetrating oil with pretty good results, but I may have to "brew up" some of this stuff.
btw - I am generally lazy and I do often times apply "none". The nuts come off pretty easily, but usually with the bolt broken off and still attached.
Old 10-06-2009, 08:30 AM
IBHarley's Avatar
IBHarley
IBHarley is offline
I use a home mix in an oil squirt can from an automotive supply store no plastic parts
Old 10-06-2009, 09:35 AM
Captain Itch's Avatar
Captain Itch
Captain Itch is online now
Sponsor
Kroil is the best I have ever used..Have a 46 Indian,and a 49 wl Harley.Have run in to a rusted bolt here and there..
__________________
www.Captain-Itch.com
Old 10-06-2009, 09:50 AM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
Doesn't nail polish remover contain acetone? I think most of them come in plastic bottles.
Old 10-06-2009, 12:05 PM
OD_Cleaver's Avatar
OD_Cleaver
OD_Cleaver is offline
For breaking loose rusted fasteners, none of these penetrating oils compare to my favorite - a propane torch and water.
I heat the part then douse it with water. I repeat the cycle at least two more times. If it is still frozen, repeat the cycle. The hotter the part is before being doused with water the better. I have used this technique on brake bleeder screws to axle U bolts with success each time.
Note: I have never had to use this technique on my bike, only on my cars and trucks that I drive thru Minnesota winters. My bikes never get that kind of rust.
Old 10-06-2009, 12:46 PM
piasspj's Avatar
piasspj
piasspj is offline
The home brew works. Been using it for years.
Reality is I have all of these products, usually use whichever I find first and they all work better if you soak the rusted joint multiple times over a day or two.
Old 10-06-2009, 12:57 PM
cdestuck's Avatar
cdestuck
cdestuck is offline
Keep Kroil around all the time. Found out about this stuff as I have a 1949 Farmall Cub and frequent that forum site also. And thoe guys are use to dealing with rusty, corroded bolts. Good Stuff
Old 10-06-2009, 05:59 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
I had a set of thirty year old head pipes rusted onto one of my Trident heads, which I couldn't get loose. I sent the whole works down to Mike at Baxter Triumph in Marne Iowa, who got them off using Deep Creep, a foaming penetrating oil made by Sea Foam.
I've been using it ever since with great results. I have found it at marine dealers, who use it to get rusted props off drive shafts on boats motors.
Quick Reply: Penetrant test results
