Will MU85B 16 fit on my 02RKC
Old 06-26-2006 | 12:23 PM
harris48cars's Avatar
harris48cars
Default Will MU85B 16 fit on my 02RKC
My bike came with the MT90B 16. I want to put the newer RK tire on it. Has anybody done this? I know the new MU85 is 3/10" wider (divide that in half for each side). Will it fit?
Gary
Old 06-26-2006 | 01:26 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Will MU85B 16 fit on my 02RKC
Yes, it will fit...
Only thing that you MIGHT have to do is remove the wiper off of the belt guard......
Old 06-26-2006 | 01:57 PM
spartns's Avatar
spartns
Yea, what he said. The wiper will rub the tire. It doesn't hurt it, it just messes up the white wall.
Old 06-27-2006 | 12:02 PM
harris48cars
ORIGINAL: Shovelhead Bob
Yes, it will fit...
Does the"wiper" serve a real purpose Shovelhead? I mean, if it provides protection for the belt or something really beneficial, I probably wouldn't remove it.
Gary
Old 06-27-2006 | 05:24 PM
lilarlen's Avatar
lilarlen
Yes it will fit and you will love it!
I have an 03 RoadKing with the newer MU85B tire, all I did was trim the guard (the front half) and install this $35 spacer.
http://www.pingelonline.com/rear_sprocket_spacer.htm
Tire looks great and bike runs fine!
Here is a sticky from another forum about all of this.
http://www.*****************/forums/sh...ad.php?t=66062
Old 07-10-2006 | 05:00 PM
craigcap's Avatar
craigcap
Stage I
Lilarlen,
Tried to click on your link below http://www.****/forums/showthread.php?t=66062
doesnt' work (probably cause of the ***, which may be due to need for security to enter that particular forum).
Any other way I can get to that link/info?
Im I correct in understanding that if you get the spacer you recommend, then you DON"T have to trim or remove the wiper on the belt guard? I have an '02 road king.
Thanks!
Old 07-10-2006 | 06:27 PM
lilarlen's Avatar
lilarlen
craigcap,
I sent you an email about all of this, look for that.
Old 07-10-2006 | 08:37 PM
harris48cars
While we are back on this subject, I took the, print out, of the spacer to my mechanic and he said, "If you move the rear pulley, then you have to do something with the front pulley". I wonder.......
Gary
Old 07-11-2006 | 08:36 PM
lilarlen's Avatar
lilarlen
Hello Gary,
Good question.
If the dealership I work with is correct, the front stayed the same even with the new rear tire. In 2004 when HD switched to the newer bigger rear tire. all HD did was replace the back with a smaller (and HD says stronger) belt, change the rear pulley and change the rear fender some. (the lip on the inside). Now I am not HD nor a dealer so I can not tell you if that is correct or not… I can tell you that all the spacer does is just move things over some so everything fits again when you install the bigger rear tire.
Note: When I switched to the bigger rear tire my bike had 45k miles on it and the dealership told me that the current belt had worn a spot on the front where it rotated all the time and I might feel that until a new wear spot had been broken in.
But I have to admit that using the spacer is not the only method to install the new MU85B rear tire and if someone is not comfortable with using it I would say don't.
I know of some people that switch everything over… front and back on pre 2004 bikes to get the new MU85B tire installed. Some others have just installed the tire and trimmed the front of the guard to get things to work. (no spacer) You can pick what you like/ want.
Here are the specs on the two tires:
The specs for D402 (MT90B16) rear tire, pre 2004:
Overall Diameter: 25.70
Width: 5.20
Tread depth: 9/32
Load rating: 827 lbs
Specs for the newer D402 (MU85B16) rear tire used since 2004:
Overall Diameter: 25.71
Width: 5.51
Tread depth: 11/32
Load rating: 908 lbs
If you want the larger rear because of the “better” mileage ect. that HD claims you get from it but are not sure you want to mod your bike… maybe look at this tire from Dunlop.
Dunlop Elite 3 (Replaces the old 491Elite II)
Width: 5.15
Tread depth: 10/32
Load rating: 830 lbs
Bolts right on your bike, no mods needed!
The Elite 3 has a different tread pattern and a hard rubber compound which is why it gets better “use” mileage, or so I have been told. I have not used this tire, I am using the spacer and running the MU85B. So far no trouble.
lilarlen
Old 07-12-2006 | 04:13 PM
huffhuff's Avatar
huffhuff
i'm on my second MU85 on my 2001 RK. i trimmed the guard enough to clear the tire and nothing else. the extra 2/32nds of tread adds a lot of mileage to the tire. about 15K average as opposed to 11 or 12K. about $100 delivered from american motocycle tire in colorado for blackwall.
LazySundays
02-26-2017 07:49 PM
Jsteiner
03-27-2013 10:27 AM
killbee
Wheels/Tires
10-11-2012 07:28 AM
Rowdy25
Wheels/Tires
08-19-2009 01:56 PM
Marsh
12-06-2008 05:01 PM
