Street Glide lower Fairings
Old 06-26-2006 | 07:39 PM
Abnmarine's Avatar
Abnmarine
Default RE: Street Glide lower Fairings
ORIGINAL: GliderXXX
Those look great on your Street Glides' fellas! They give the bike that husky look I'm going for! Couple of additional questions;
-Do they inhibit your feet movement much while on the boards? Seems they would keep your feet pretty constricted, but wondering about the ability to move them long ways "into" the fairing a bit.
I can still place my feet on the boards just like before installing the lowers
-Same question as above; do they force your hiway pegs to have to be set farther out than without the fairings or do you have just as much flexibility?
It does limit the height of where you mount your pegs but with the 360 degree mounts I am able to adjust them to where I am comfortable
-In regards to wind noise/buffetting and turbulence, have you found these to be an effective deterrent to those problems, i.e., "calming the turbulence?"
It helps calm the wind down from hitting the torso. I do notice the wind when having my legs out on the Hwy pegs
thanks...I think I'm getting some, particularly since I've all but decided I'm not ever getting a tour pak for the SG. I'll do a luggage rack on back first and equip with a T-Bag.
Thanks again for the feedback...anyone else...pictures??
Old 06-27-2006 | 01:31 AM
GliderXXX's Avatar
GliderXXX
ORIGINAL: Abnmarine
ORIGINAL: GliderXXX
Thanks Marine! I'm getting a pair for sure now.
Old 06-27-2006 | 10:32 AM
Abnmarine's Avatar
Abnmarine
No problem.
ORIGINAL: GliderXXX
ORIGINAL: Abnmarine
ORIGINAL: GliderXXX
Old 06-27-2006 | 04:33 PM
wldhogn's Avatar
wldhogn
ORIGINAL: bpterb
Will I lose my highway pegs when I install the fairings? I see abnmarine has highway pegs on, but I have very short legs.
Thanks!
Kuryakyn makes a nice set of highway peg mounts for use with lower farings. You can find them here: Kuryakyn Peg Mounts I used them on my previous RG with lower farings installed. They make 2 versions .. one for shorter legs (#4526) and one for longer legs (#4520), they wrap around the lower farings nicely. Good Luck!
Old 06-27-2006 | 05:25 PM
Loch's Avatar
Loch
I’ll never take the lowers off my Ultra Glide. They are SaWeet!
Pretty soon you guy’s will be buying tour paks and adding cruise control too.
Hounddog1010
10-31-2016 07:42 PM
jsalamon
05-17-2016 02:54 PM
cjw
08-18-2012 05:33 PM
redmustang1990
05-30-2012 01:57 PM
buckwheat
02-02-2008 01:55 PM
Quick Reply: Street Glide lower Fairings
