Can't Cut Down Newer Tinted Windshield?
I have an '09 Electra Glide Classic and wanted to cut down my tinted 9" H-D windshield. A local glass shop that used to do this said they wouldn't cut down windshields anymore because of the material. Is there something unique about the newer windshields that causes problems? Thanks.
I think they are still some type of Lexan / plastic. If that's the still the case, I am guessing that the glass shop wants to score it and snap the piece off and it chips around the edges, they dont want to be responsible.
I would tape off on both in and outside of the shield, draw the curve you want on the outside face and either cut it with a band saw or saber saw with a fine metal cutting blade. When you cut plastic or lexan if you cut too fast it will reglue it self back together behind the saw blade....it heats and melts the plastic. File the edges and your done. Placing tape actually does two things....prevents chips and prevents scratches from the saber saw or band saw base. I have cut a lot of plastic and Lexan with both a saber and band saw without issue. I cut a whole lot more formica kitchen and bath counter tops with a saber saw and its a lot harder and chips far easier than a HD windshield.
Once you get the edge sand and everything the way you want it you can use a little heat to finish the edge. a propane torch or a turbo lighter will do the job and give you a near perfect factory edge. it doesn't take much just touch it and back off and work your way around the windshield.
