08' TC96 w/ Woods TW7H cams ?
Anyone here use Woods TW7H cams in a 103 build on their bagger? I already have the heads, they are ported with 1.94 intake and 1.5 exh valves and cc'd. I will use my TD Rineharts and PCIII, Wiseco 9.5 /1 forged pistons for a bored TC96 to a 103. Not into a hot rod bagger, just want more than it is and a little thump from the exhaust.
Look into the Tman 525 0r the Tman 590 cams. They work great and will give you a quiet running valve train.I also dont have any trouble with pinnging with these cams.
Just finished a 08 road king 96"(stock bore,pistons and stroke)with the Tman 525,9.5 compression and a set of Baisley Super stock heads with a true dual exhaust and ended up with 100 tq and 95 hp SAE. If that was on an older bike with a 5 speed it would have been 5-10 higher in the numbers.
thanks! For a few years Bob Wood and T man were teamed up. Looks like now they are competitors. I used Woods cams in a build b4 for my Wide Glide 3 and really liked what I ended up with for not just numbers but how it performed I then used a TW9F .650 lift, ended up with a 113hp/116tq with a 95" TC88. I do like the look of Tmans TR590G...comparing that with Woods TW-8-6. Looks like I may jump up one size from my origional intension...its the hot rodder in me, lol. Thanks again for the referal of Tman.
