LED LIGHTS AND CRUISE CONTROL
RE: LED LIGHTS AND CRUISE CONTROL
However you may need to add a load stabilizer (which is basically just some added resistance) if you have the factory alarm. Since they use less power the bike thinks they are burnt out and will give you the quick flash when you use the turn signals. THis is for the turn signals obviously but I imagine the brake light would cause similar TSSM problems.
ORIGINAL: ZookHD
Not true. My bike is a 2005 EG with an RG Front end. I have an LED tail light and CC. Both the CC and the tail light work great.
[IMG]local://upfiles/13976/CABDB9916AC44C2A87AAAEDAC174B094.jpg[/IMG]
What they are saying is correct. I installed LED turn signals front and rear with LED clear tail light lens. I also used the load equalizer and the run turn mod for the turn signals. This was done on my 06 Road Glide and the cruse still works fine. Go ahead and don't worry about this one.
Jackson800
Electrical/Lighting/Alarm
05-20-2015 10:24 PM
redsled
11-12-2011 06:54 PM
