07 swap to Brembo...Anybody?
Old 09-30-2009, 07:00 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 7,137 Likes on 3,665 Posts
Default 07 swap to Brembo...Anybody?
Has anybody swapped the 07 or earlier calipers to the newer Brembo's? is it doable? The braking power on the Brembo is so much better...What is involved.
Old 09-30-2009, 07:13 AM
timvan's Avatar
timvan
timvan is offline
many have..do a search
you need the calipers, rotors master cyl and plumming
Old 09-30-2009, 07:45 AM
Bushpilot's Avatar
Bushpilot
Bushpilot is offline
I have done searches on this and have not been able to answer. If anyone has removed the nissin system and put on brembo ABS Please speak up.
Old 09-30-2009, 08:08 AM
skratch's Avatar
skratch
skratch is offline
Received 4,362 Likes on 2,539 Posts
a lot of people have made the switch from the nissin brakes to the brembo. but i don't think you'll be able to go as far as retrofitting the abs.
Old 09-30-2009, 08:15 AM
dog155's Avatar
dog155
dog155 is offline
Have to add, it is so much less expensive to install Lyndall pads if you really want to be able to stop the bike,in the shortest distance possible.If it is pure bling you want hanging off the bike,then go for it.No doubt you will certainly be better than stock either way you go.
Old 09-30-2009, 09:12 AM
twincam47's Avatar
twincam47
twincam47 is offline
The Nissin ABS system was a stand alone ABS controller unit and did not interface wih the ECM. The brembo system uses the Delphi ABS controller and it IS interfaced with the ECM. The controllers will NOT swap.
Old 09-30-2009, 10:35 AM
gunnert's Avatar
gunnert
gunnert is offline
I respectfully disagree with Dogs suggestions that Brembos are bling. There is a reason they are expensive, they are worth it. http://www.qtmi.com/ This is the URL for the US distributor for Brembo. They are expensive! You must go with with the Brembo rotors for the full effect.
As far as ABS goes, there is not retrofitting on a Harley.
Old 09-30-2009, 10:47 AM
Hog Yild's Avatar
Hog Yild
Hog Yild is offline
I totally agree with this comment! I have an 07 and converted to the 08 stock Brembos upfront and they are like night and day in comparison, I wouldn't go back. It is one of the best changes you can do to your bike. No ABS, just the rotors, calipers, reservoir and levers (both brake and clutch to look alike). You can find used ones on ebay and pull it all together. WVultra has a great write up on doing it.
Old 09-30-2009, 07:41 PM
WVULTRA's Avatar
WVULTRA
WVULTRA is offline
Agree with Hog Yild 100%! The '08 and up Brembos are a major improvement in braking for the earlier models!
http://www.box.net/shared/nhergtkq5r
This will give you a good idea of what's involved.
IMO, the '08+ H-D Brembos are the finest factory braking systems ever offered for these heavy Touring models.
:cheers:
Old 09-30-2009, 08:31 PM
Notgrownup's Avatar
Notgrownup
Done double sintered pads already...improved the stopping but not as good as the Brembos...
Quick Reply: 07 swap to Brembo...Anybody?
