Inner Fairing Swap
Old 09-28-2009 | 05:52 PM
Hdard's Avatar
Hdard
Default Inner Fairing Swap
Does anyone know if the inner fairing from a 07 FLHX will fit my 08 Ultra without any fabricating? Thanks for any responses.
Old 09-28-2009 | 06:12 PM
stuart1270's Avatar
stuart1270
I believe the only difference is that the 08 does not have the hole for the throttle cable since the 08 uses electronic control.
dawg's Avatar
dawg
You would need to add a fourth hole on each side for the adjustable deflectors as the 08 and later uses a 4 screw mounting system as opposed to the older 3 screw. You would need to plug the throttle cable hole. You would also have fairing mirror holes in the FLHX fairing.
stratplexi
Touring Parts
01-02-2012 09:43 AM
Nellybelle
01-02-2011 08:45 PM
meanjean
06-02-2010 09:45 PM
Buzzsaw
11-29-2008 11:32 PM
kickstart pan
03-28-2008 12:04 AM
Quick Reply: Inner Fairing Swap
