Critique my build sheet
![Question](https://www.hdforums.com/forum/images/icons/icon5.gif)
I'm going to bump up my Cubes to 103 and was wondering if anybody had any constructive input on the components and gameplan in which I'm going to go about getting there.
Due to financial constraints, I'm unable to buy HQ, Axtell, GMR, Rev Perf. and all the other reputable hardware so I'll use my own cylinders and heads.
Gameplan:
1. Bore my own cylinders to 3.875
2. Set deck height of pistons to "0"(probably going to have to shave the bottom off the cylinders)
3. Flat Top Cast Screaming Eagle pistons
4. Use a .030 Cometic head gasket
5. SE255 cams
6. Have my own stock heads "messaged" by Big Boyz
7. Manual Jims Compression releases installed in heads
8. Dyno tuned by The Dyno Difference in DFW, Tx. using my SERT or possibly get the TTS
If I did the math correctly this should equate to a 10:34.1 Static Compression with a Cold Cranking Compression of 212.5
Did I miss anything or is there something you fellas would or wouldn't do as outlined here?
Any unforeseen issues I may come against before or after this build?
Gameplan:
5. SE255 cams
I definitely wouldn't try to port and polish my own heads! I am a tool and die maker and could do the work if I knew what needs re radiused and where to remove material. I don't. That's a specialized job and should match your pistons and cams. There are valve shroud issues and a lot more. Got a flow bench? There are a lot of "kits" out ther where you get heads done, pistons and cams to match the compression and the flow of the head work. I think over 10 to 1 compression might be too much for S.E.255 cams. If you're going to send out your heads, buy cams and pistons anyway you probably won't spend any more by getting matched parts that are proven to work well together. Check out head Quarters, Zippers, Dave Mackie and others and you might find something that works better than what you are planning.
Sounds pretty good. While a 0 deck height would be nice, I wouldn't really obsess about it. If you measure and are in the hole a little, give those specs to Bean and he can mill your head surface if needed and cc your head volume and/or get a thinner (say .020) gasket to compensate for being down in the hole and keep your quench at ~ .030-ish.
Good luck with the build. I'm about 2 weeks from tearing into mine and sending it off.
One more thing.... like Northside said, compression over 10:1 might be too much for those 255's. They have a really early intake valve close and will jack up that ccp higher than you might want. Could cause hard starting, detonation, etc. I've got the Andrews 26H right now with stock compression and I don't think I'd want to use them with much more static compression. YMMV.
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
See these often make good torque for a millisecond, and then fall flat on their face. Ill put a plug in for the woods 6, running in my 98" build at 10.2:1 and it hits 100ftlbs at 2500 rpm, and carries it all the way to 5700rpm. Peaks at 109/109. Andrews 54h is also another good option at the compression you will be at, have seen them yield impressive results as well.
Don't "F" with the heads on this build, other than possibly adding the compression releases.
The rest of the plan is sound. You'll be closer to the 9.7:1 range, which is more in line with how those cams are intended to be used.
You're doing a mild build that will make a reasonable improvement in the ride. Don't over analyze things or try to make it something it is NOT.
btw - did I mention.... DON'T F&$# WITH THE HEADS for this build? You may want to do something better later on, and if you do something now (for very minimal return), you'll be buying another set to get "worked" next time around. TRUST ME on that!
![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
