Wiring Suggestions
Old 09-23-2009 | 11:35 AM
Knoxville81's Avatar
Knoxville81
Default Wiring Suggestions
I just purchased 12.5 Wild 1 Chubbys for my 2010 Street Glide and would like some input from anyone who has made the conversion from the stock bars to an ape hanger style in the 12-14 in tall variety. Is the kit from Novello the way to go, or should I look at something else?
Old 09-23-2009 | 11:59 AM
tencrore's Avatar
tencrore
I did the WO513's 8.5" Mini Apes and I used the Novello extension kit. The same would apply to your situation.
If I remember correctly, the instructions don't mention the use of solder. They only state to connect the pins into the "female" end and then use a piece of heat shrink to insulate them.
I strongly suggest to solder the connection. This serves two purposes; one, to ensure good electrical connectivity and second, to ensure that the joint does not come apart when you pull the wire through the bar.
I then put a long piece of heat shrink over all wires, once the extensions were in place. This made it easier to pull the entire loom through the bars.
Hope this helps.
Old 09-23-2009 | 12:13 PM
Knoxville81
I see they sell the kit in different lengths, I was thinking a +8 in this case. Does that sound correct?
cprhed
01-02-2018 11:52 AM
HappyScrappy
10-28-2013 07:08 PM
aroz34
04-08-2013 09:06 PM
canadagrown
06-19-2011 08:36 PM
chromedome
11-26-2008 12:45 AM
Quick Reply: Wiring Suggestions
