Inner Primary Bearing
Old 09-23-2009 | 08:46 AM
t059736's Avatar
t059736
Default Inner Primary Bearing
I have been told; by the mechanic whose working on my scooter, that he had to replace the "Primary Inner Bearing".
I've checked the starter and clutch diagrams in my Touring guide "Service manual" and see no bearing by this description.
His original job was to find the where the oil leak coming from under the bike and around the lower primary gasket cover.
I've checked the internet and found lots of references to "worn primary bearings, replacement of primary bearings, etc" but cannot find on which assembly - clutch or starter, these bearings are used.
I ride a FLHT; '03.
Your assistance would be greatly appreciated.
G
Old 09-23-2009 | 09:12 AM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
Inner primary bearing supports the tranny input shaft behind the clutch.
Old 09-23-2009 | 09:22 AM
CroK's Avatar
CroK
It's the bearing on the main shaft of the tranny, not the Main Shaft Bearing but the bearing which supports the inner primary housing between the drive pully and the clutch hub.
Does that sound too much like what Eyespy said?
clarkchriston
10-26-2020 11:04 AM
MURPHCC1
59
08-17-2017 05:14 PM
RoadHog659
09-08-2011 05:31 PM
abearcarver
EVO
02-24-2009 03:07 PM
Tahoe
01-25-2006 03:43 AM
Quick Reply: Inner Primary Bearing
