Best "mild" cam for 96" baggers??
09-21-2009, 07:01 PM
What is considered to be the best "mild mannered" cam for a 96" bagger with NO headwork or displacement??
Thanks for any advice
09-21-2009, 07:29 PM
Why are you asking this?
You already said you've chosen the Andrew 54 on VTF.
09-21-2009, 07:37 PM
I ran the 54's stock. I wrote a review a few weeks ago. I just installed the 103 kit with head work and it really woke the cams up.
09-21-2009, 08:09 PM
I just had the Head Quarters HQ 500 installed in my 2008 Street Glide(stock 96", no head work). I already had SE intake/filter stage 1, Bassani Megaphone slip-on mufflers(stock head-pipes) and the SE Super Tuner. The bike pulls very hard from around 2500 rpm and up. Dyno numbers are 83 hp/95 tq. Great bolt in cam, not noisy and a very nice idle to the bike now, sounds like you mean business...
09-21-2009, 08:31 PM
My guess would be if you are wanting "mild mannered" the stock cams would be just fine.
Dennis
09-21-2009, 08:57 PM
09-22-2009, 07:23 AM
Quote:
Originally Posted by
PhilM
That thread was regarding a 103" build that I may or may not go ahead with.
This thread is looking at the best cam if I stick with stock motor.
09-22-2009, 07:27 AM
I run the 575 that is a 96 bolt in and will work with a 103 or a 110. However, as I posted above you can go with the infamous doughnut cam (Andrews 54)
09-22-2009, 07:38 AM
Andrews 26H does a great job in a 96" stocker.
09-22-2009, 07:55 AM
I dropped the SE-204 in my 09. 81hp/99ft lbs. Prob could get some better numbers with a better tune.
