Broken inner fairing mounts
Old 06-20-2006 | 05:36 AM
Blue SOG's Avatar
Blue SOG
Default Broken inner fairing mounts
Kinda odd isn't it? I haven't heard of this happening to anyone else... The background: The dealer had the outer fairing off trying to locate and fix an intermittant blinker problem when he noticed 3 of the 5 inner fairing mounts were broken. [&:] He jokingly said I ride too hard...[8D] Maybe my hard riding coupled with the horrible roads up here did it. I had noticed the fairing shakin a little more than ususal lately but attributed it the the 95" engine build. It's being replaced under warranty and we both agreed that my "hard" riding should not have caused this. Anyway, just wondering if anyone else has seen this?
Old 06-20-2006 | 06:22 AM
SeaHag's Avatar
SeaHag
Default RE: Broken inner fairing mounts
Don't be surprised when it happens again. The stock fairing brackets are notoriously cheap and weak. If you haven't heard of this happening, you just haven't been paying close enough attention because I've read of many, many cases of this happening on the forums.
I had my fairing apart this winter to paint the inner. I took the opportunity to bolster the cheap brackets with some strategic welding. I've also heard of many people welding little "L" brackets to the ends where they are prone to break.
Old 06-20-2006 | 08:19 AM
tcfamy's Avatar
tcfamy
Two years ago When I first bought my bike I thought the fairing was moving around too much. When I removed the outer I found the left upper bracket fractured. Shaped new and slightly beefier upper mounts from stainless steel and so far so good. The originals are very weak and have a bend in the worst spot. I will bet if more people looked they would find a fracture or crack developing in thiers also.
Tom
Old 03-28-2007 | 07:07 PM
solorider's Avatar
solorider
Did a search and found this thread from last year. I took my fairing off this past weekend and sure enough, both brackets were broken right under the speakers ('06 Street Glide). Since Harley can't get their chit together on these things, I'm wondering if anybody knows of an aftermarket supplier. If not, I'm gonna trade my two broken ones in for two replacements under warranty and then try to beef them up.
Thanks in advance.
Old 03-28-2007 | 07:46 PM
fatboylust's Avatar
fatboylust
As I saw, it the upper flange was created by cutting away one side of the angle from the bracket before it was bent 90°, which created a very sharp corner at the intersection on the cut and the bend. Good sheet metal work would have added a relief hole prior to the cut and subsequent bend to relieve the stress this creates. Without this the vibration will work on the stress riser of the sharp corner until it fails. Unfortunately the factory’s design lacks any evidence that it was engineered. When I inspected mine I drilled relief holes in the corners of the brackets but will continue to monitor their condition and hope for the best.
FBL
Old 03-29-2007 | 01:46 AM
BigTom's Avatar
BigTom
If someone would make some better brackets I bet they could sell lots of them on this forum.
I would buy some for sure.
Old 03-29-2007 | 08:32 AM
jbhawley's Avatar
jbhawley
Check out this link...found it in another posting. Looks to be the same style as the HD OEM bracket but made of stainless steel. Cost a bit more, but SS is not pront to breaking like the HD OEM monkey metal brackets.
http://cgi.ebay.com/ebaymotors/Harle...82607652QQrdZ1
Old 03-29-2007 | 08:38 AM
jbhawley's Avatar
jbhawley
OOPS...looks like the auction on ebay is over and the website doesnt show a listing for the SS bracket. I have emailed the seller to inquire about more brackets.
Old 03-29-2007 | 12:23 PM
Snobal's Avatar
Snobal
ORIGINAL: Phil
Phil,
I had the left fairing bracket replaced in my '06 Ultra on Monday of this week. I found the origional one was broken when I was looking for a rattle a few weeks ago.
Have you checked your front motor mount? My early '06 had the old style and it craped out within the first 10K. Again, I found it, not the dealer --- but they replaced it under warranty.
I plan to build my own fairing brackets if the cheap $hit HD ones break again.
Old 03-29-2007 | 12:51 PM
yota's Avatar
yota
Is there a way to tell if the brackets are broken without pulling the fairing open..If the are broken and you do not open up the fairing, what will happen.?
Quick Reply: Broken inner fairing mounts
