Valve stem caps w/pressure indicater
Been looking at these at the local Discount Auto Parts, they come from the manufacturer set at a certain pressure (32lbs and 36lbs). You screw them onto your tires valve stem and, if the pressure drops below the setting a little red ring becomes visible. There is a green ring that is visible if pressure is above the setting. Well, been looking at them for a couple of weeks but couldn't get around the "cheesy" factor. Finally bought me a set of the "36", I run 36 in the front and 40 in the rear. Installed them and, lo and behold, my rear tire was low (31). Fired up the compressor, filled the tire. I know, it sounds cheesy but they really don't look bad. I suspect most people won't even notice them as they are mostly hidden by the brake rotors. Anyway, I know they ain't chrome and ain't from Harley but they do seem to make it ez to check the tire pressure.
Been using the 38 psi "green band" types for 18 months. No leaks, no problems, and accurate. I find that it's far easier to do a quick 15 second visual check, than un-cap and use an air guage. Therefore I do the quick check almost every time I throw a leg over the bike. I think that's far safer!
