front wheel bearing failure
Old 09-21-2009, 07:18 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Are all these reported failures on the same kind of rim?
Anybody?
  #32
Old 09-22-2009, 06:54 AM
gary_montague's Avatar
gary_montague
gary_montague is offline
Hard to see how just replacing the bearings could fix allignment issue. If there is a problem with the bore in the wheel, the only fix would be a new wheel. I guess you could try to ream it, but the machinist would charge more than a new wheel. I think if that is in fact the issue, you need to record when the new bearing is replaced and plan on watching it to see if it also fails. There is one other possible issue not mentioned. That is the inner bushing. When the axle is tightened, the inner races should be tight to the bushings, in effect one unit. The outer races or race must have room to align with the inners. In the case where side torque is applied to a ball bearing, failure is pretty much assured. I have seen that in large blowers when a crew did not place the retaining ring for the housing in the expansion groove. Failure pattern will show uneven wear on inner and outer race to one side mostly. In blowers, tis is often due to thermal expansion when a shaft excedes 2 ft. and temp. varies.
  #33
Old 11-18-2009, 07:30 PM
LX HEMI's Avatar
LX HEMI
LX HEMI is offline
Originally Posted by carpetride
I would like to know who makes those bearings. If HD is starting to use cheaper (chinese) parts to boost profits, my 06 will be my last harley. That bike is way too new for that to happen.
Mine say "Mexico"
  #34
Old 11-18-2009, 07:32 PM
LX HEMI's Avatar
LX HEMI
LX HEMI is offline
anyone think putting the entire hub with the bearing still in it, in the freezer, it'll be easier to pull the bearing out?? I need to get mine out for powder coating. cheap homemade tool ideas for removing?
  #35
Old 11-18-2009, 07:46 PM
IBHarley's Avatar
IBHarley
IBHarley is offline
just found a bearing puller from Harbor Frieght for 39.99 with a 20%discount coupon that will work with the Harley bearings http://www.harborfreight.com/cpi/cta...emnumber=95987
  #36
Old 11-18-2009, 07:50 PM
LX HEMI's Avatar
LX HEMI
LX HEMI is offline
sweet! Thx. Let yall know how it works out!
  #37
Old 11-18-2009, 07:51 PM
LX HEMI's Avatar
LX HEMI
LX HEMI is offline
where'd you find the coupon??
  #38
Old 11-18-2009, 08:42 PM
Hog Yild's Avatar
Hog Yild
Hog Yild is offline
It works great to remove the bearing, that's what I've been using.
Just remember when pressing the new bearing in to use a tool, sleeve, etc. that contacts only the outer race of the bearing and never pound them in with a hammer.
  #39
Old 11-18-2009, 09:59 PM
LX HEMI's Avatar
LX HEMI
LX HEMI is offline
awesome, just bought the tool from harbor freight. probably sell it on here for $30 shipped after i use it.
  #40
Old 11-18-2009, 10:07 PM
IBHarley's Avatar
IBHarley
IBHarley is offline
Full page ad in Bagger Magazine had the 20% off coupon
Quick Reply: front wheel bearing failure
