front wheel bearing failure
VERY GOOD ADVICE!! Leave them in the freezer overnight.
It's definitely worth a try. I had my mainshaft bearing replaced in warranty 10 months after expiration.
Was out today on my 08 ultra and the left front bearing failed bike has 15,000 any tricks for removing the old and pressing a new one in manual says use their puller and installer but putting it in looks like a threaded rod and some washers out of warranty by 2 weeks it figures
Thanks Ian
Thanks Ian
this morning I pulled the wheel and using a long punch with the edge ground to an angle I was able to push both bearings out of the wheel new bearings I used a socket that fit the edge of the bearing and tapped them in wheel is back together and test rode it and all seems good but I guess only miles will tell
thanks for all the suggestions Ian
Followed the manual for primary side first that's the side with the tire valve since I don't have ABS both bearings were the same it all went pretty smooth and is now done local dealer had the bearings for 19.00 apiece
Pressure Washing and S100 ... Keep the Hell away from the Bearings... Putting Bearings in the Freezer is a New One on me... But will keep it in mind makes sense as freezing it would make the OD a little smaller for fitment.. although the Inner Race would also contract a little getting it on the shaft..
