Check Engine Light Help?
I'm sure I'm missing something...I found the post that describes how to determine the Check Engine Light code(s) by jumping pins 1 & 2 of the data link connector under the right side cover of my 06 FLHT but much to my dismay...pins 1, 3 & 4 are available but pin 2 has a plug - am I looking at the correct connector? Has something changed with the 06's? Help? Check Engine light comes on sporadically since installing the Active Performance Exhaust and AC kit (with download). I also realized this a.m. that I goofed and did a fill up with low octane fuel which may be aggrevating the condition - but having the codes output and defined would sure help.
Thanks in advance.
Thanks in advance.
RE: Check Engine Light Help?
You should not have to jump any pins to see your code. You should be able to see the code on your odometer by using your ignition switch. Can someone please post the instructions on this? I can't seem to find mine.
ORIGINAL: nh_glide
Thanks in advance.
Thanks in advance.
I found the link that has instructions on how to check your own code:
http://www.harleyhog.co.uk/0405troublecodes.htm
Try it and let me know if it worked for you.
Kahuna
Kahuna
