What Learned about Trailering!!!
Old 09-19-2009, 09:09 PM
jcbpa's Avatar
jcbpa
jcbpa is offline
Default What Learned about Trailering!!!
Don't use a handle bar harness... It sounded like a good idea but cost me a day in the shop while on vacation. Tie down where there are no potential electric connections.
Old 09-19-2009, 10:05 PM
oldmanwayne's Avatar
oldmanwayne
oldmanwayne is offline
good tip= what is the better way to tie down?
Old 09-19-2009, 10:14 PM
Mike5959's Avatar
Mike5959
Mike5959 is offline
front forks above the fender mounting location.
Old 09-19-2009, 10:39 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
Also tying down on the handle bars can result in the bar bending down and dropping the bike when you hit a big bump. Many people have had that happen.
Old 09-19-2009, 11:02 PM
jberg's Avatar
jberg
jberg is offline
I installed tie down points on the forks where the driving lights are mounted. They come from Kuryakyn. Perfect because they avoid handlebars and the straps easily clear lower fairings. All the pressure is on the suspension where it should be.
Old 09-19-2009, 11:38 PM
jasnusc's Avatar
jasnusc
jasnusc is offline
I wanted to get those but on my SG the blinkers are apart of that bracket. i would have to move my blinkers somewhere else to install those hooks.
Im hoping someone like Kuryakyn will come out with some that have the hook and the mount for the blinker.
Old 09-20-2009, 02:54 AM
mike5511's Avatar
mike5511
mike5511 is offline
I use the frame, two front down tubes. Pulled forward and out. Front wheel in a chock. Strap the rear off from the passenger floorboard brackets to the floor. What could possibly be better?? Several thousand miles this way with no problems. Nearly turned the whole thing over this year when I dodged a bicycle seat in the road too violently. The bike never moved.
Old 09-20-2009, 04:54 AM
jcbpa's Avatar
jcbpa
jcbpa is offline
I found that the engine bars on the front; the bars that protect the bags (frame mounted; not horizontal bars; and one on the tire.... kept me in good stead no matter the terrain.
Old 09-20-2009, 06:29 AM
ilanshanon's Avatar
ilanshanon
ilanshanon is offline
5th Gear
I wouldn't mount on the engine guards. I began to do that once and noticed that the guards were starting to bend a bit. Luckily no damage done, but will never tie on to the guards.
Old 09-20-2009, 07:26 AM
jsimo7's Avatar
jsimo7
jsimo7 is offline
I tie the front to the forks where the fender attaches and the rear to the pass floorboard bracket. I pull the rear suspension down but this method allows the front suspension to still work and absorb some of the road bumps.
I take my bike every Feb from Ohio's snow and ice to somewhere warm for a week and have trailered thousands of miles tied like that with zero problems.
Quick Reply: What Learned about Trailering!!!
