Notices
Battery Life
Old 09-19-2009, 08:43 PM
jcbpa's Avatar
jcbpa
jcbpa is offline
Default Battery Life
Likely subject to many influences, but I have two good years and 15,000 miles on my stock battery. It feels like it is struggling a bit.... How long do these things last... It's turning a bigger starter and a 117 motor... lots of lights on the bike too... I'd rather be safe than sorry... should I change it during the off season....
Old 09-19-2009, 08:48 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I assume you have comp. releases,but with a bigger motor(starting) and extra lights this can tax the battery.
Of course all depends on how often you ride and storage with/without a charger also.
I still have the original on mine.
Old 09-19-2009, 08:53 PM
jcbpa's Avatar
jcbpa
jcbpa is offline
Yes, electric SE releases and I ride as much as I can... probably will do 10-12000 a year... not as much as I'd like, but back surgeries, took me out for 3 mos this year and of course living in PA does not help.
Old 09-19-2009, 09:05 PM
Hx3's Avatar
Hx3
Hx3 is offline
The last battery I replaced (my 99) was seven years old when it finally gave up. I wouldn't replace at two years unless it completely dies. My one year old OEM HD battery sometimes acts as if it's struggling a little, but it keeps working fine.
Old 09-19-2009, 09:08 PM
jcbpa's Avatar
jcbpa
jcbpa is offline
I'm pretty good with it, keeping it on the trickle during the off season or if I'm not going to ride for a few weeks because of surgery
Old 09-19-2009, 09:30 PM
will2002's Avatar
will2002
will2002 is offline
Received 2,132 Likes on 1,030 Posts
My 02 Ultra still has the stock battery. Never used a battery tender, still PLENTY hot.......... Now, since I post this, I'm sure that it will be dead in the morning!
Old 09-19-2009, 10:55 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
I plug the bike into the tender when I put it back into the garage. It stays on the tender until the next ride. I sold a bike this spring with over 7 years on the battery. I collect sport cars and bikes. Some sit a long time. I have never had a battery problem. The tender is the only way to go. Even if you ride every day a tender still is a benefit.
Old 09-20-2009, 12:26 AM
Anthony8858's Avatar
Anthony8858
Anthony8858 is offline
My 2005 RKC still has original battery.
ALWAYS on trickle charge when I'm not riding.
Old 09-20-2009, 06:42 AM
Bikerdad61's Avatar
Bikerdad61
Bikerdad61 is offline
Using a battery tender is the key to long battery life.
Old 09-20-2009, 07:15 AM
racerdj's Avatar
racerdj
racerdj is offline
+1...I plan on this routine this winter.
Quick Reply: Battery Life
