? on power source
Old 09-17-2009, 05:00 PM
shakak's Avatar
shakak
shakak is offline
Default ? on power source
I have an 08 SG and I am installing a GPS. I took off the ferring and saw 2 wires that come off the headlight harness (1 having a red safety cap other black wire) I tested this with a volt meter and its hot when the ignition is turned on my question is can I use this as my power or is it designed for another use?
Old 09-17-2009, 05:18 PM
dawg's Avatar
dawg
dawg is offline
Received 3,239 Likes on 1,850 Posts
Yes certainly. That's where I have my GPS wired. It is used for HDI models only.
Old 09-17-2009, 07:47 PM
JohnScrip's Avatar
JohnScrip
JohnScrip is offline
As long as you've got it cracked open, it's not much to hook it to the ACC switch wiring. I can't remember which wire was in/out, but I remember that it was very obvious. That way, you can at least kill the power to the plug when it's not in use.
Old 09-17-2009, 10:17 PM
Hrlyrider's Avatar
Hrlyrider
Hrlyrider is offline
They must of messed my 08 up because my acc wire is under the seat
Old 09-17-2009, 10:25 PM
shakak's Avatar
shakak
shakak is offline
Its under the seat I looked into using that acc switch
Old 09-17-2009, 10:55 PM
JohnScrip's Avatar
JohnScrip
I mean splicing into the wires *on* the ACC switch. Lets you keep the port under the seat and lets you hook power up easily.
Old 09-18-2009, 08:01 AM
iclick's Avatar
iclick
iclick is offline
ACC switch wiring:
Orange/Rede = 12V when ignition on
Orange = 12V when ignition and ACC switch on
Black = ground
I'm not sure why you'd want an additional switch (i.e. ACC) to power the GPS on/off since it has its own power switch.
Old 09-18-2009, 08:02 AM
iclick's Avatar
iclick
iclick is offline
It also eliminates the need to run the wires under the tank, which IMO is unnecessary.
Old 02-15-2011, 07:08 PM
CruzN's Avatar
CruzN
CruzN is offline
I took a simpler approach.
I just solider wires on to the back of the cigarette light in the fairing.
on the back of the cigarette light inside the fair, I believe center is hot ..
butch50
04-28-2012 11:03 PM
TedMan
03-09-2012 08:56 AM
petemac
06-06-2008 12:57 PM
plysat
04-20-2008 09:24 PM
Doc
11-23-2006 02:31 PM
Quick Reply: ? on power source
