Road Glide fairing removal
Old 08-25-2008, 02:58 PM
Chicago Spike's Avatar
Chicago Spike
Chicago Spike is offline
Yep, you're getting hung up on the 2 hooks. Lift up and push in slightly to get off the hooks. A service manual would be a big help to you too
Old 08-25-2008, 11:49 PM
meveratt's Avatar
meveratt
meveratt is offline
+2 on removing the headlight assembly before reinstall. Absolutely essential!
Be careful not to overtorque the Torx screws when reinstalling. Guess how I know...
Old 07-17-2010, 02:32 PM
used2jeep's Avatar
used2jeep
used2jeep is offline
3rd Gear
How do you get the headlight assembly back on when the fairing is in place?
Old 07-17-2010, 03:19 PM
FlamedFXR's Avatar
FlamedFXR
FlamedFXR is online now
Received 1,686 Likes on 704 Posts
When you remove the headlight you will see the little squeeze clips that hold it in. All you have to do is line them up and push in till they catch. Just make sure they all line up before you push.
Old 07-17-2010, 06:45 PM
used2jeep's Avatar
used2jeep
3rd Gear
SWEET! No more "Please, please, please don't scratch"!
Old 07-17-2010, 09:14 PM
SPARKY01's Avatar
SPARKY01
SPARKY01 is offline
Originally Posted by hdslam
Remove all the torques, leave the windshield on. Apply pressure, upwards, to lift off the clips which hold the outer fairing. Protect fender w/ soft towel. After fairing is over clips, pull towards you, gently. Lower it slightly and remove the molex connector for the headlamp assembly.
RE-Install; It is easier to keep the head lamp assembly out at this time. This will allow you to see the clips for the fairing mount. If you keep the headlamp assembly in, you will only get frustrated. W/ the headlamp out, it will only take a couple of minutes to put back together.
Re-connect molex to headlamp and lock in headlamp....DONE!!!
I have had mine off several times w/out any problems.
For "Thundercloud"; You more than likely have the incorrect speakers on the bike, meaning the ohms. This will cause head unit to overheat and cut-out. If speakers were changed. Check wiring also, this will cause it overheat and melt down.
+1. taking the headlight out is the ONLY way!!!
Old 07-17-2010, 09:32 PM
lp's Avatar
lp
lp is offline
Received 2,853 Likes on 1,601 Posts
First time it took me an hour to get the fairing back on.
Now I can re-install it in seconds. Just line up the outer the fairing with the inner fairing, push up and in. No headlight removal needed.
lp
Old 07-18-2010, 08:12 PM
Chicago Spike
You've probably heard it before but I finally remembered what your avatar picture reminded me of from when I was a kid watching Banana Splits;
Wheelie and the Chopper Bunch
Old 09-03-2010, 09:44 AM
Brettcr's Avatar
Brettcr
Brettcr is offline
lp
HOLY *****! took seconds to get off and hours to get back on last night and still scared i pushed it into place! Didn't go together easily! Usually don't have to many issues with my bikes but this RGC is a new beast to me. Will be looking at doing it again this afternoon. Just can't take any chance that i may have screwed something up. Only a week old.
BTW... Anybody have any pics up of the install to show what i should be looking for? I do have the Service manual but the reinstall isn't the best instructions when you don't know what clasps you are looking for.
Thanks!
Old 09-03-2010, 10:01 AM
RedDogNC's Avatar
RedDogNC
RedDogNC is offline
Just to back up what has been said. Last summer to install new speakers I had to take it off. Man was I nervous but this thread and others helped. First time I put it back on without taking the light out and it was an hour ordeal. Since then I have taken the fairing off 3 times and I can have it back on in minutes. That's why I love this site!
Quick Reply: Road Glide fairing removal
