proficient motorcycling: break, slow, lean & roll
"Proficient Motorcycling": break, slow, lean & roll
I am reading "Proficient Motorcycling" and on page 75 the technique to properly go through a curve is to break in a straight line as much as possible, release the breaks and make sure the engine speed is smoothed out, lean and roll on the throttle at the same time.
I'm not talking about counter stearing in this post just the methods to get the engine and your overall speed correct for a turn/curve. I've only been riding for a couple months and I'm not sure I have this practiced and just sort of play every corner/turn by ear.
Are these the methods that riders typically use for a smooth and safe ride?
This technique applies to any vehicle about to enter a curve. The vehicle (bike in this case but it applies to cars as well) needs to be stable as it enters the curve. Hence the braking and downshifting, throttle matching and clutch releasing etc al should happen BEFORE the entry to the corner/curve.
Anything that causes the vehicle suspension to unload or destabilize during the curve/corner can lead to a hairy experience.
It's been raining here in Houston, Tx, for a couple weeks (off and on ... but mostly off) and I've been resolved to learn how to ride in the rain so I've been out there. Do these techniques change with rain substantially? My main technique has been to just slow way down and curves/turns have not been an issue but I have not been focused on any real technique, save falling over.
Does the lean of the bike and a throttle roll allow for most wet roads to be taken without issue?
I re-read that book at the beginning of every season, some pretty good strategies and techniques. If you have not taken an MSF or riders Edge course, I would highly recommend that as well. They pretty much drilled the SLOW-LOOK-LEAN-ROLL thing into my head so much that I still repeat it to myself while entering a turn.
Took the MSF on one of those 450s and sort of didn't worry about it. Now with 1,500 miles on my FLTR I can read this book and start to really understand what they are talking about. So I'm focused on understanding and making sure that I form good habits. My ERC is in October and I'm really excited about practicing and getting more skills today, and getting more during the class.
Yep and Proficient Motorcycling is still The Bible for riding.
Check speed going into the turn, idealy be at the speed you can safely enter the turn in, the use the counter steering technique, look where you want to go and apply some slow roll-on power to take you through the corner and exit.
No brake lights are great, but gentle braking isn't a sin if you need to scrub off some more speed, but apply a lot of front brake while leaned over and the bars will get ripped from your hands and you'll be down before you know what hits you.
'Ride like a Pro' is a good DVD also, particularly if you're new to cycling...teaches some very basic techniques up to a little more advanced. I like to practice the basics regularly (for example on my way to work at 6am this morning I ducked into a local park and just did some tight figure 8's for a few minutes).
