Front oxygen sensor
Old 09-12-2009 | 11:25 AM
lmb1485's Avatar
lmb1485
Default Front oxygen sensor
I have a 207 ultra clasic ,the engine light came on .the code is p0134 which says front oxygen sensor is inactive.Now following the wires from the front sensor it comes to a harness between the front frame tubes, right by the cross brace.this harness is unpluged and as for as I know always has been.the enginge light just now started to come on with this code.Should I plug it together.or is it more than that? thanks
Old 09-12-2009 | 11:33 AM
1sweetglide08's Avatar
1sweetglide08
I would plug it back up and see what happens. If you have a Power Commander installed you need a O2 eliminator plug on the unpluged O2 sensor.
Old 09-12-2009 | 12:19 PM
rjmac53's Avatar
rjmac53
let us know...
Old 09-12-2009 | 05:10 PM
lmb1485's Avatar
lmb1485
the 02 plug goes on the front and rear.and the harness stays disconnected.this is the set-up if you have a power commander,which I do.now I'm thinking it can only be a mappin problem or the pc111 went bad
Old 09-12-2009 | 08:02 PM
WVULTRA's Avatar
WVULTRA
lmb:
If that pc111 is bad, I'd plug up those O2 sensors and get a TTS Mastertune tuner! You can have good power and good mileage with the right tuner!
MasterGunz1775
05-09-2017 07:21 AM
gottah8me
05-02-2017 08:37 PM
cajunlowrider
10-07-2016 01:03 PM
harbourside
12-13-2012 08:55 AM
ScReaMnEagLE22
Exhaust System Topics
07-08-2009 07:48 PM
Quick Reply: Front oxygen sensor
