Horn Removal
Old 06-15-2006 | 11:38 AM
jarman's Avatar
jarman
Default Horn Removal
Has anyone ever removed the horn from their bike? I looked at mine last night. I tried removing it from the motor bracket but didn't want to force the stud. There is a nut on the back of the bracket that the stud runs through. Is it welded or just on there really tight?
Jarman
Bud Steed (05-21-2021)
Old 06-15-2006 | 12:07 PM
Mr Wonderful's Avatar
Mr Wonderful
Default RE: Horn Removal
The chrome hex nut is just tight. The bracket and "cow bell" will come off as a unit. Then just unplug the connectors and it's free to disassemble. About as easy as it gets!
Old 06-15-2006 | 01:13 PM
roadkingboy's Avatar
roadkingboy
Yeah agree with that, nut just tight, and horn comes straight off by unplugging the wiring, I fitted a "mini beast" air horn which is LOUD! and screws right onto the existing mount.
Old 06-15-2006 | 05:39 PM
Primo's Avatar
Primo
BEWARE!
If you will be putting the original horn back on please be careful to torque only to factory specs.
Overtightening will ruin the horn and leave you with the sound of the horn as if a sock were stuffed in it.
The stock horn is not only weak sounding but also very fragile.
If switching to another better horn then bombs away.
Primo
Old 06-15-2006 | 06:01 PM
jarman's Avatar
jarman
I'm really looking to get rid of the whole thing and need to remove the rubber spacer and stud from the mount beside the choke button. Any help would be appreciated. Thanks for the other replies.
Jarman
Old 06-15-2006 | 06:02 PM
liltrk's Avatar
liltrk
It WILL come off.
Old 02-09-2011 | 06:00 AM
donzrx's Avatar
donzrx
2nd Gear
Jarman
Hi Jarman,
I am having the same problem on my 2010 Fatboy Lo. The stud holding the rubber spacer won't come out. How did you get it off?
Old 02-09-2011 | 08:22 AM
grbrown's Avatar
grbrown
The rubber horn mount is symmetrical. After you take off the horn the stud you see is identical to the stud holding the rubber spacer to the mounting bracket. While you unscrewed a nut off the stud to remove the horn, you must unscrew the rubber mount off the bracket, as it is screwed into a welded on nut. The nut is going nowhere! The rubber mount is steel backed, so with care you may be able to use a pipe wrench to unscrew it. Hope that helps!
Old 02-09-2011 | 10:34 AM
gmc's Avatar
gmc
Once the horn is off I think you can double nut the stud and back it out of the bracket or use a pipe wrench like grbrown states.
sumncguy
2018+ Softail Models
36
08-04-2024 10:28 AM
meadows.harrison
03-25-2013 09:12 PM
Doc o
07-10-2012 05:50 PM
steelerdude1
07-14-2011 03:32 PM
t059736
03-17-2010 04:25 PM
Quick Reply: Horn Removal
