Heal Shift Peg = Heal Rest?
I find that I rest my heal on the heal shift peg sometimes, mostly without even realizing Im doing it, when I do realize it I promply remove my heal from it. My question is, is there any mechanical danger in this? Could any damamge be caused by my heal's weight and pressure resting on the rear shift peg? Not to concernd about the peg or shift lever its self, Im thinking more along the lines of transmission etc.
I'd try to avoid the practice as much as possible. Since I don't use the heal shifter anyway, it was one of the first things I took off the bike.
Ride Safe,
Steve R.
Yes, there is. If you're putting pressure on the shift lever, you'll also be putting pressure on the shift mechanisms inside the transmission, particularly the shift forks, and it will cause premature wear. Not a good thing.
Ride Safe,
Steve R.
Ride Safe,
Steve R.
IMO, and assuming it's your heel you're referring to, yes, a constant pre-load on the shift linkage could very well lead to undesirable wear to the parts affected.
Ride Safe,
Steve R.
Ride Safe,
Steve R.
Don't let it become a habit. Also you can install extended levers that don't cost valuable ground clearance but allow you to use the entire floorboard for your feet while retaining the heel shifter.
Honda had problems with this way back when, when aftermarket companies started offering heal shifter "upgrades" for the GL1500's. The shift forks were good for about 20 to 25k miles of the riders keeping their foot on the mechanism. Once Honda figured out what was going on, they quit honoring tranny warranty claims on any bike that had the aftermarket heal shifter installed.
In Harley's case, the heal shifter is a factory item so that may not be the case but I certainly wouldn't want to find out!
Ride Safe,
Steve R.
