Is there a way to increase the length of the friction zone? I noticed that I really don't grab until I'm near the top of the release point of the clutch handle.
My cable has about 1/16th - 1/8th play at the handle.
you need to adjust the clutch adjustment nut. refer to your service manual. it is a simple procedure.
Originally Posted by dawg
1/2 turn on adjuster screw and a nickel's width at the perch for play and you should be happy.
I went exactly like the manual says. Back off the locknut, turn the adjuster screw until it lightly seats then back off 1/2 to 1 turn. Then adjust the clutch cable until you have 1/16 to 1/8 gap.
Road Dawg got it. If the clutch is releasing high instead of backing off 1 turn, back off between 1/2 and 3/4. Seat that screw a few times before backing off to make sure it isn't binding. Easy.
Then do yourself a favor and put anti seize on your dome screws.
I only backed it off a 1/2 turn.
I might try more gap on the cable tonight. I know I don't have a nickle's or 1/8" worth. Mine's prolly closer to the 1/16th.
Good call about the anti-seize...
Just wondering, how many miles do you have on your bike?
Do you "ride the clutch" a lot or let it fully engage before accelerating or in between gear shifts. Do you slip the clutch a lot when taking off? Maybe you've worn the clutch with your riding style.
What kind of oil do you have in the primary and is it the right amount?
I just traded for an 2010, it was the 1st 1000 mile service. New Syn 3 oil in the primary.
I don't "ride" the clutch but it doesn't seem right being that far out. Makes it harder to work the clutch.
