DynoJet Map for stock 96 with SE204 cams?
I don't think it would help at all but i have an autotuned map for SE 204's in a 103" with SE slip on's. I'm sure it would be too rich for a 96". With those cams i noticed the map for front and rear cylinders are quite different. Also i was able to advance the timing all across the range from 1 degree at low rpm to 4 degrees at WOT. Bought the auto-tune as i couldn't find any map close with these cams. It's going to take some dyno tuning for each cylinder as the map is fairly complex with added fuel in some ranges and subtracted fuel in others. $$$$$
Did you contact DynoJet?
I bought an extra license for my PowerVision to tune my 2003 Heritage with a big bore kit (95ci), SE203 cams, and V&H big shot exhaust.
The DynoJet site only seems to have tunes for2006 and newer.
Jaime at FuelMoto did not have a map for my combination and directed me to DynoJet, PVtech@dynojet.com. I'm sure they have a tech address for the power commander too.
They had me email a copy of the tune on the bike (HD big bore download) and less than 24 hrs later they sent me a new tune. I compared the AFR & timing tables between the tunes and the new tune seems to be a lot better. I base that on my very little knowledge of computer tuning. I am going to flash it and ride the bike today to see the difference.
I got excellent customer service from DynoJet for a tune combination not in their current inventory.
Worth a shot.......
Worth a shot.......
Just a quick follow-up.....
The custom tune that DynoJet made for my 2003 Heritage works excellent! I went for a 3 hour ride today and it felt like a different bike. Seat of the pants improvement is substantial over the HD download and there is no more popping on decel.
I'd send them an email if you can't find a tune for your set-up.
good luck...
good luck...
Rowdy1
07-12-2015 06:30 PM
