I hope going forward you check your oil more frequently than every 4500 miles! Then maybe your "files of crazy $hit" will get shorter. Anyway...thanks for the laugh!
I don't think it burned that much oil. Like others say, check the oil before any trips and for sure when you get it back from service. If I had to guess I say you're leaking somewhere, oil cooler (if you have one) is a common source of leaking if the gasket is not seated correctly.
You want something done right....do it yourself! And if you dont or can't...check the dipstick from time to time....
Originally Posted by Mike5959
I was riding down the highway at about 80 mph and engine make a strange knocking noise. I eased off the throttle and revved it a bit and heard it again. I pulled over and it was fine. The next day everything seemed normal. Fast forward 2 days I was on the highway and it happened again. This time I noticed my oil pressure was only reading under 10 while under load @ 80. I pulled off and checked my level and the dipstick was bone dry! I had to add 2 quarts. I am due for my 5000 mile service I am at about 5500 miles right now. I am not leaking any oil so I am thinking that the last oil change wasn't filled up to the proper level. I shouldnt have burned up 2 quarts right?
